Table to Table bug in ArcGIS 10.1 ?
3998
10
02-12-2013 06:38 AM
AlbertoAloe
Hi guys.
I'm not sure if what I'm observing here is a bug but for sure is something weird.
I'm just exporting a table (let's say some million records) from a SDE database (sql server 2008 r2) to a file geodatabase and I get the following strange situations:
  1. When I use ArcCatalog 10.1 (backgroung GP 64 bit) installed on Windows Server 2008 r2 and the file geodatabase is on a local drive the export fails after a while with error 000224: Cannot insert features (which is already weird because I was trying to insert rows !!). When I check the output table I see that  some records were exported. If I repeat the same task the failure is the same but at another point in time (different number of records exported before failure)
  2. When I use ArcCatalog 10.1 on Window Server 2008 R2 and the file geodatabase is a on network drive everything is ok
Point 1 and 2 repeated on Windows 7 are just fine. Point 1 and 2 repeated on Windows Server 2008 R2 with 32 bit geoprocessing  produce the same trouble.
I'm trying to investigate all the possible cases....meanwhile if anybody has run in a similar trouble.......
Alberto
AlbertoAloe
Asrujit,
the issue is still around. Another collegue with same environment confirmed it.
Maybe it is somehow related with this one....http://support.esri.com/en/knowledgebase/techarticles/detail/41119/?WT.mc_id=EmailCampaign15945
Alberto
