Split Line into Segments Using Multiple Points on that Line
2422
01-28-2022 04:16 AM
EdwardL
I have 2 files. One is a linear file that represents a transit line. The other is a point file that represents stations on that line.
I want to split the line into multiple segments using the point locations. Each segment would represent a section between stations on the transit line.
How can I accomplish this? Please let me know. I’d appreciate it.
EdwardL
Huh, I didn’t think about that. I’ll try playing around with the search radius and let you know if it works.
Thanks again for the help!
JayantaPoddar
You could use Split Line at Point (Data Management)—ArcGIS Pro | Documentation (Requires Advanced license of ArcGIS Pro/ ArcMap).
Think Location
EdwardL
Thanks for the reply.
So I tried that tool using a stations file that had 30 points. The output ended up being only 2 segments.
I was very confused and I’m still not sure why it did that. I was expecting more segments.
JayantaPoddar
I believe the points might not be exactly coinciding with the line features.
Define a Search radius (maybe 10 meters or as you feel appropriate).
Think Location
EdwardL
