I am trying to spatially join road areas with road center lines after the center line snow removal status has been updated. A spatial join between these two would capture the status of the center line and place it in the road area. I get the results I need when I right-click on the feature class and do a spatial join with attributes. When I build a model and use the spatial join from the Analysis toolbox I don't get the attributes. Is there a work a round for this in model builder? I am using ArcInfo 10.0 with no service packs. Just in case....I cannot do a regular join because we have a lot of roads that currently do not have names. Any input is appreciated.
You can join features by right clicking on them in the table of contents and select join. When I perform this join with attributes I get the desired results. Even when I run the spatial join tool from the toolbox I get the desired results. But not from model builder. The output data is permanent and I am joining center lines to road areas. I think this may fall under NIM076186 but have not gotten confirmation from ESRI.
I attached a screen shot of the model. I was wondering if my settings were correct. Snow_Removal_Area (2) is a feature layer for data type while the center line file is a table view. [ATTACH=CONFIG]30937[/ATTACH]
rfairhur24Under Join Data you have a drop-down list in ArcGIS Desktop that allows you to choose "Join data from another layer based on spatial location" which I believe is a Spatial Join.
