Setting new toolbox as permanent in ArcGIS Pro?
3165
03-19-2018 06:09 AM
JotaUs
Similar to this thread - how to make a arctoolbox permanent in toolbox list - I am seeking to do the same in ArcGis Pro. Any thoughts?
DanPatterson_Retired
In pro, you normally access custom/user toolboxes through the project pane as shown in the figures here
http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/save-geoprocessing-tools-in-your...
you can make any tools you create included in future projects via your project template.  I think you are expecting to see it in the main Arctoolbox tree all the time
access is through the Project
JotaUs
Thanks for suggestion. I already had the preferences set as above. Not really. I am not able too see it in the Arctoolbox tree all the time, and that is the issue. However it is possible to find the tool, if I type the name in the Find tools bar (geoprocessing window). Nonetheless, I still seek to find how to add new toolboxes and make them visible on the tree list, near to all the other default toolboxes.
That's what I am saying... it doesn't save there, it is from the toolboxes in the Catalog view.
You could try putting it in this folder
C:\...PRO install folder....\Resources\ArcToolBox\Toolboxes
but that would help with sharing amongst other users, whereas the project/template approach would enable you to roll the toolbox in with the share
