selecting the Geodatabase used for input to a ModelBuilder tool
1338
05-11-2011 05:36 AM
CharlesSmith1
I want to use the JavaScriptAPI, ModelBuilder and Geoprocessing services.
I want to pass in a user string with the name/directory of his geodatabase and then use a feature class or feature set as input to a ModelBulider tool.
Are there any code examples showing this?
Does this work with variable substitution?
Do I need an ArcPy tool to connect to the geodatabase to use as the input?
Charles
FrankVignati
not sure of your question, do you just want the user to select a geodatabase when they fire off the model? if so then use a workspace variable in the model and make it a parameter
CharlesSmith1
Hi Frank,
Thanks for the reply.
I want to publish the tool as a geoprocessing service and so I want to have a string input parameter with the path and name of a personal database on our ArcServer.
Does this make sense?
Charles
FrankVignati
sorry i misunderstood what you are trying to accomplish, maybe you should post the question in the arcgis sever forum for a better response
