Select first row of feature class and export to shapefile using SearchCursor
2010
06-11-2010 12:05 AM
KevinCressy
I am trying to test a portion of code for a script I am trying to put together.  I would like to go the the first row in my shapefile using the SearchCursor and then export that row to new shapefile (eventually I want to develop this to export each row - however the first row on its own is fine for now).  I have tried the following script but this does not work, can anyone tell me where I am going wrong?
import arcgisscripting
gp = arcgisscripting.create(9.3)
gp.overwriteOutput = 1
inpolys = r'C:\Python_Test\Polygons.shp'
infc = inpolys
rows = gp.SearchCursor(infc)
row = rows.next() # take me to first row in polygon file
# Make a temp layer
gp.MakeFeatureLayer("C:\Python_Test\Polygons.shp", "TempLayer")
# Copy row features out
gp.CopyFeatures("TempLayer", "C:\Python_Test\Test.shp")
DanPatterson_Retired
http://arcscripts.esri.com/details.asp?dbid=14127
will do it if you select a unique ID field for the export (ie FID)
JeffWard
Honored Contributor
Here is what I came up with.  This code loops through all of the features and inserts them to the new shapefile.  If you run it multiple times, it will stack the new features on top of the old ones.
gp.overwriteoutput = 1
# set the workspace
gp.workspace = "C:\\Python_Test"
inPolys = "Polygons.shp"
#need the spatial reference for the CreateFeatureClass tool below
dscFC = gp.Describe(inPolys)
sr = dscFC.SpatialReference
newFC = "NewFeatures.shp"
#if the new shapefile doesn't exist it will be created
if not gp.Exists(newFC):
    gp.CreateFeatureClass_management(gp.workspace, newFC, "POLYGON", inPolys, "", "", sr)
oldRows = gp.SearchCursor(inPolys)
newRows = gp.InsertCursor(newFC)
oldRow = oldRows.Next()
while oldRow:
    #if you need to do anything to the features before they are inserted
    #into the new shapefile, this is where you would do it.
    newRows.InsertRow(oldRow)
del gp, dscFC, sr, oldRows, newRows, oldRow
I hope that helps you out.
Jeff Ward
Jeff Ward
Summit County, Utah
