Results window not opening
5259
12-24-2014 09:06 AM
YvonneYen_Liu
Hi there,
I'm a newbie to ArcGIS spatial statistics, so please bear with me.  I'm running some tools like Average Nearest Neighbor and I can't get the results.  I go to Geoprocessing, Results and nothing comes up.  I tried looking for a results file in C:\Users\<username>\AppData\Roaming\ESRI\Desktop10.3\ArcToolbox\History and there's XML files that are a log of my actions.  Still, no results.
Help!  Your advice is appreciated!
DanPatterson_Retired
1  Does it happen with all projects?
2  Do you happen to have 2 monitors?
YvonneYen_Liu
Thanks for responding, Dan!
Good question!  I do work on two monitors, but I'm now running off of one display.
I repeated the steps and checked off "Generate report".  I also disabled background processing.  Success!  I see now where ArcGIS is saving the HTML report file.
I still can't open the Results window, but I can get the report file.
Now, onto the EVEN harder task of interpreting the results 🙂
YvonneYen_Liu
I also tried to run a tool on another file and, still, the Results window does not open. 😞
Just humor me...turn on the other monitor...if the results window remembers the last space it was in..then it is there...otherwise...no clue
MikeCusi
A right click on the taskbar then "Cascade windows" will work on all open windows even the hidden ones.
Cheers
