Removing road from 2m elevation data to achieve an area without roads
435
01-08-2013 08:22 AM
AlirezaNickman
Hi Guys,
Hope you doing well.
I am working with a model in which I need to compare an area inclusive road in that with the same area if the roads are removed.
I am using a 2 m resolution elevation data (grid format).
How can I do that in a fast way , because the area that Im working is relatively large.
Thank you so much in advance. \m/
Nickman
