Python toolbox gpCalculatorExpression example
2650
10-30-2013 12:17 AM
antoniogomez
Hello Forum
I'm new at python toolboxes and I`m trying to create a toolbox that shows a typical Calculator Field Parameter but I cant find any code example of how to manage it.
Assuming two parameters in my python toolbox ( param0 a dbase input and param1 a Calculator Expression), how could I feed the GPCalculatroExpression with the fields passed as a dbase table parameter?
Thank you in advance
Toni
KeaganAllan
I do not know much about Python, however I do find it useful to set the process you want to do in the Model Builder and then export the model to Python Script.
File - Export Model - To Python Script
Opening that file in Notepad or similar text editor allows you to look into how a process / geoprocessor uses syntax to reference the various inputs and parameters you want to use.
I know its not much, but hopefully it will get you on track.
Good luck,
K
