Problems with "Add Field"
5434
12
02-17-2016 01:53 PM
BrunaCavalcante
Hello everyone!
I'm having problems to add a field on my shape's attribute table. When i try to add a Double column, it should show the options "scale" and "precision" for me to fill, but it keeps showing the options "alias", "allow null values" and "default value". How can i change that?
Thank you for the help!
P.S.: I'm using ArcGIS 10.
AdrianWelsh
MVP Honored Contributor
yeah that's true. Sometimes old shapefile habits are hard to break!
BrunaCavalcante
But I i'm working with a shapefile, not a geodatabase...
DanPatterson_Retired
shapefiles don't support alias
Add Field—Help | ArcGIS for Desktop
other readings
Working with fields in shapefiles by adding a field in ArcCatalog—Help | ArcGIS for Desktop
in geodatabase you can only change properties when the table is empty,
Alter Field—Help | ArcGIS for Desktop
and shapefiles would be the same
