pass the field name as parameter to the next tool
1173
09-14-2010 09:51 AM
by Anonymous User
Not applicable
Original User: maxh718
I am creating a tool using Python, the output of the tool is a feature class.
then I want to use the field name as the value of the dropdown list of the field selection to select a field as the the buffer size, but the problem is I can not see the field names.
Did I miss something?
def main():
    inFC=arcpy.GetParameterAsText(0)
    outFC=arcpy.GetParameterAsText(1)
#    outFC=createUniqueOutputName(inFC)
    distance=arcpy.GetParameterAsText(2)
    arcpy.AddMessage("split %s into %s by %s"%(inFC,outFC,distance))
    #arcpy.AddMessage("%s--- %s "%(env.workspace,env.scratchWorkspace))
    if arcpy.Exists(outFC):
        print "%s is deleted"%outFC
        arcpy.Delete_management(outFC)
     ## create outFC
    out_path = os.path.dirname(outFC)
    arcpy.AddMessage(out_path)
    out_name = os.path.basename(outFC)
    arcpy.AddMessage(out_name)
    geometry_type = "POLYLINE"
    template=inFC
    arcpy.CreateFeatureclass_management(out_path, out_name, geometry_type,template)
    arcpy.AddMessage("before splitting")
    splitLineByDistance(inFC,outFC,200)
if __name__ == '__main__':
    main()
by Anonymous User
Not applicable
Original User: curtvprice
This is controlled in the parameter tab when you add the script tool to the toolbox (not in ModelBuilder). Hope this helps.
curtvprice
If you right click on your script tool .. create variable .. field argument. This will create a model element for that script tool argument.
then in your model you can connect that model element to the next tool (assuming it's a field object).
An annoying issue is when the input is a string (say the name for Add Field) you sometimes need to convert the type - this can be done with the Calculate Value tool which can be set to return an object of specified type. (ie a Field object)
