Numbering of records that have same ID with sequential numbers that start from zero,
4125
11-12-2015 09:55 PM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, 4 buildings take (42/1/Beituniya) as their ID. What I need is to add new field (BuildingNumber) at which I want to stick sequential numbers for these buildings.
How this might be performed?
Thank you
Best
Jamal
Jamal Numan
LukeSturtevant
You could try an update cursor like so:
import arcpy
getMax = max([row[0] for row in arcpy.da.SearchCursor("TestPoints","FREQUENCY")]) +1
for i in range (getMax):
     j = 0
     with arcpy.da.UpdateCursor("TestPoints",["FREQUENCY","BuildingNumber"]) as update:
         for row in update:
             if row[0] == i:
                 row[1] = j
                 j += 1
             else:
                 j = 0
             update.updateRow(row)
DanPatterson_Retired
Moved to Geoprocessing
Use the GeoNet Community Structure​ for better placement of questions.
LukeSturtevant
import arcpy
     j = 0
         for row in update:
             if row[0] == i:
                 row[1] = j
                 j += 1
             else:
                 j = 0
