Null values after joining a csv file to a shapefile layer on ArcGIS Pro
4084
09-11-2022 02:53 AM
ErmioniVereketi
Hello everyone,
I am trying to join a csv file to a shapefile layer (points) and after the joining all column values are <NULL>
I checked the joining field to be in the exact same type
Here is my data:
 The Shapefile table
The csv file (imported on ArcGIS)
DanPatterson
MVP Esteemed Contributor
and what were the join fields?  I see at least 1 field that looks like a number but is left justified, meaning it is text and not a number
... sort of retired...
ErmioniVereketi
The join fiels are "Loomweight" from the Shape File and "Object" from the csv file
DanPatterson
As suspected,  Loomweight is a text field (left justified) and Object is numeric (right-justified),
You can't join numbers to text EVEN if they both look like numbers.  A common issue.  cast one of the fields into a new field to the opposite of what it is using the field calculator (eg int(Loomweight) in a new integer field like LoomWght2)
ErmioniVereketi
Many thanks! What I did eventually was to convert the csv file to a dBASE on ArcGIS and then join the dbf file to my shape file
