Need to find Extent to set the dataframe ?
4044
02-18-2015 05:16 PM
DEAF_PROBERT_68
Honored Contributor
I am working on loading several NAIP l to my ArcMap and writing a script to call them ...now I am curious if there is an extent that can I get able to work to set them to extent overview ?
I looked at the extent but not sure which one is the right one. Can anyone help me out ?
Robert
SepheFox
Do you mean the extent of each NAIP? If you right click on each NAIP and select properties, under the source tab, it should have the extent of the layer, which will be four numbers, a min/max x and y.
