Multipart To Singlepart tool fails
5374
6
07-14-2011 11:15 AM
RobW
Hi, I am running ArcGIS 10.
The feature class I am using is fairly small and the geometry is repaired.
In ArcGIS 9.3.1, I can run a Multipart To Singlepart on this feature class with no issues.
However in ArcGIS 10, for the same feature class, the Multipart To Singlepart tool fails and the whole application (ArcCatalog or ArcMap) just crashes.   I have also upgraded to SP1, but to no avail.
Has anyone else run into this problem and found a solution.
Thanks for any insight you can offer.
RobW
The topology for this feature class has also been checked and is OK.
Oddly enough, when I export the feature class to a shapefile and do the multipart to singlepart, it works.
However, I still need/would like for it to work in a file gdb format.
DanLee
by Esri Regular Contributor
Could you send the data to me: [email protected]? I would like to see if it is a bug that needs to be fixed.
Thansk,
RobW
After sending sample data to ESRI, a bug was identified and will likely be fixed in the next release of ArcGIS (10.1).
DeonaEvans
Do you know if this supposedly got fixed in 10.1.  I'm having a problem with it on files that did work in 10.0.
SebastianRoberts
Thanks for this post.  It seems Esri still hasn't fixed this bug.  Using ArcMap 10.2.1, with a file geodatbase, I got repeated crashes using the Mulitpart to SinglePart geoprocessing tool as well as trying to explode multipart features.
However, converting to a shapefile, both the geoprocessing tool and exploding features in an edit session work just fine.
DanLee
Hi guys,
The bug (NIM079950) we found with Rob's data was fixed in Aug. 2011 and went in 10.0 SP5. The problem was very data specific. I have just retested the case using our current development version, it worked fine.
For those who have seen issues in 10.1 or 10.2.1, please email me ([email protected]) your test data, as fewer features as possible that still can reproduce the issue. It is likely a different problem.
Thanks!
