Model builder iterations of shape and raster
4588
03-15-2015 04:23 PM
johnpolo
I have a shape file of 150 lake buffers. I want to use model builder to create a new shape file for each buffer. Then I want to use the buffers as masks to extract smaller rasters from a statewide raster. I built a model that will divide the original shape file into separate files and that worked. I changed the model by adding a step for extracting the mask from the statewide raster. It worked only for one feature, instead of 150. What do I need to tweak? I attached an image of the model to show the steps.
KishorGhatage
Model looks good. Try useing %Value% in the output name.
KishorGhatage
