Measure distance between points in order of time/date in ArcPro
1325
11-15-2019 10:36 AM
JessicaShapiro
I have points representing movements of animals with a Date Year Julian field. I'd like to measure the distance between each point based on the order of the date so I know how far an animal has moved without manually using the measuring tool. I will be needing to measure the distance between a few hundred points at a time .I would like to do this in ArcPro and comfortable with the Model builder.  Any suggestions of how to accomplish this would be appreciated.
DanPatterson_Retired
A sample of the data would help.
In any event, if you have a field in a table that will permit date sorting or can be converted to sorted order, then determining the sequential point differences is fairly simple in planar coordinates but doable if coordinates are in decimal degrees.  Permanently sorting records can be accomplished using
Sort—Data Management toolbox | ArcGIS Desktop
general discussion is here
Sort records in a table—ArcGIS Pro | ArcGIS Desktop
If you lack an appropriate field for sorting, then a minimum spanning tree can be useful to connect movements which are purposeful... they will fail for wandering aimlessly situations where paths may be close together and/or cross
JessicaShapiro
How do I determine the sequential point differences in my data? I tried running this code in the field calculator but all distance values came back 0. I have the following fields in my table: ObjectID, Shape, DateYearAndJulian, Latitude,Longitude, Distance.
JessicaShapiro
I was using the wrong data type for my distance field. Never mind.
