I think my issue is that my dictionaries don't have anything in them.... the lists of fcs and rasters print fine...
#fgdb of rasters being clipped
source_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Pluvial_1in100\Pluvial_1in100_Processed.gdb'
#fgdb of features doing the clipping
clipping_fgdb = r'E:\Boundaries\WBDHU2_Mar2014.gdb'
#preferably empy fgdb to put outputs
output_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Final_Floodplain_Bounds_No_NHD.gdb'
#list all the rasters
arcpy.env.workspace = source_fgdb
rasters = arcpy.ListRasters("*", "GRID")
print (rasters)
['FATHOM_pluv_con_002', 'FATHOM_pluv_con_005', 'FATHOM_pluv_con_006', 'FATHOM_pluv_con_012', 'FATHOM_pluv_con_007', 'FATHOM_pluv_con_010', 'FATHOM_pluv_con_011', 'FATHOM_pluv_con_013', 'FATHOM_pluv_con_014', 'FATHOM_pluv_con_015', 'FATHOM_pluv_con_016', 'FATHOM_pluv_con_017', 'FATHOM_pluv_con_008', 'FATHOM_pluv_con_009', 'FATHOM_pluv_con_003']
arcpy.env.workspace = clipping_fgdb
clipping_fcs = arcpy.ListFeatureClasses()
print (clipping_fcs)
['HUC2_002', 'HUC2_003', 'HUC2_004', 'HUC2_005', 'HUC2_006', 'HUC2_007', 'HUC2_008', 'HUC2_009', 'HUC2_010', 'HUC2_011', 'HUC2_012', 'HUC2_013', 'HUC2_014', 'HUC2_015', 'HUC2_016', 'HUC2_017', 'HUC2_018', 'HUC2_019', 'HUC2_020', 'HUC2_021', 'HUC2_022']
source_clip_fc_dict = {}
for raster in rasters:
for clipping_fc in clipping_fcs:
if raster.split("_")[0] == clipping_fc.split("_")[0]:
raster_path = os.path.join(source_fgdb, raster)
clipping_fc_path = os.path.join(clipping_fgdb, clipping_fc)
source_clip_fc_dict[raster_path] = [clipping_fc_path, raster]
print(source_clip_fc_dict)
