Loop not working in business analyst drive time - python
1449
7
06-21-2010 03:54 PM
SabitaTripathi
I have 3 shp files stored in a folder (Retailers_0, Retailers_1 and Retailers_2). I want to create a drive time by looping into each file. Below is the code. The problem I'm having is that it only reads the last file Retailers_2. Can anyone point out what's wrong in the code below?
# TestDT.py
# Created on: Mon Jun 21 2010 01:31:26 PM
# (generated by ArcGIS/ModelBuilder)
# Usage: TestDT <Input_Store_SHP_File> <Enter_Drive_Times> <Select_Drive_Time_Polygon_Output_Path>
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Load required toolboxes...
gp.CheckOutExtension("Business")
gp.CheckOutExtension("Network")
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Business Analyst Tools.tbx")
for i in range(0,3):
s = str(i)
print s
Input_Store_SHP_File = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Retailers_"+s+".shp"
print Input_Store_SHP_File
# Script arguments...
Enter_Drive_Times = "3" # provide a default value if unspecified
Select_Drive_Time_Polygon_Output_Path = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Result\\Retailers_"+s+".shp"
# Local variables...
Output_Traversed_Streets_Feature_Class = ""
# Process: 1 to 20 min Drive Time...
#tempEnvironment0 = gp.scratchWorkspace
#gp.scratchWorkspace = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Result\\"
gp.DriveTime_ba(Input_Store_SHP_File, "COMPID", "ALL", Enter_Drive_Times, "Minutes", Select_Drive_Time_Polygon_Output_Path, "", "", "false", "false", "false", "true", "false", "false", Output_Traversed_Streets_Feature_Class)
#gp.scratchWorkspace = tempEnvironment0
CedricWannaz
Hello,
     Is your code displaying 0, 1, 2 and outputting only the last file or is there even no output? Could you use CODE tags so we can see how your code is indented? You can do it by clicking the sharp (#) button in the editor.
Cedric
SabitaTripathi
It displays 0,1 and 2 but just reads the last file. I edit code with IDLE not pythonwin so sharp button is not there. Let me know if I can do any other way.
See below:
H:\FINANCE\Analysis\ESRI\Sabita\NewModel\Test\Retailers_2.shp
CedricWannaz
Sorry, I meant in the forum, as screenshot-ed below.
SabitaTripathi
Here it is:
# TestDT.py
    print i
    s = str(i)
Input_Store_SHP_File = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Retailers_"+s+".shp" # provide a default value if unspecified
Select_Drive_Time_Polygon_Output_Path = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Result\\Retailers_"+s+".shp" # provide a default value if unspecified
gp.scratchWorkspace = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\"
CedricWannaz
Then try with this indentation:
 print i
 s = str(i)
Your problem was that only the first two lines following the "for .. " were taken in the loop because of the indentation.
Best regards,
Cedric
SabitaTripathi
It worked. Thanks a lot!
CedricWannaz
My pleasure 🙂
Cedric
