Limitation of Geo-Processing tool
741
09-29-2023 08:38 AM
Shanmukha_KumariVattem
I am trying to export FGDB from Selected features in the Web Application using the Python script as a Geoprocessing tool.
I have created a Python Script that creates the FGDB file with feature class from the JSON format of Feature Collections.
Published the script as a Geoprocessing service.
And now I am passing the JSON of feature collections in the form of a string to the Geoprocessing service.
Here I am facing an issue when the size of the string exceeds more than 9MB the Geoprocessing service is failing. and it is not giving errors in the logs.
Are there any limitations to the input parameters for the string in Geoprocessing?
PeijunCai
Esri Alum
What GP tool are you trying to use in the script?
