KMZ/KML to ASCII
2481
01-25-2023 01:20 PM
arahman_mdmajid
We have a KMZ raster file which we are trying to convert to ASCII xyz data to be utilized in Petrosys/Petrel but we were able to get the ASCII txt file but that is in ESRI ASCII Raster format and can not be utilized in the target softwares.
We initially converted the kmz to mosaic datasets with the ground overlay option enabled then used the Raster to ASCII to converter but the output is not in the desired format.
Kindly advise on how can we get the ASCII file in xyz format.
Abdur Rahman
GIS Developer
Luke_Pinner
MVP Regular Contributor
