Is there a way to extract more pixels that intersect the polygon?
839
12-08-2023 10:21 AM
AlyssaRenteria
I am currently following the Esri Technical Support "How To: Extract the area of a netCDF raster layer in ArcGIS Pro". I was wondering why the end result shows missing pixels and if it's possible to include those pixels as well? I circled the area I'm referencing in the image attached.
DanPatterson
MVP Esteemed Contributor
There is an extended discussion in the help
Extract by Mask (Spatial Analyst)—ArcGIS Pro | Documentation
of particular interest perhaps is to examine the 'extent' option in the Environments tab for the tool.  Perhaps you can alter it to pick up the centers of the missing cells.
A simple solution would be to use a slightly buffered polygon to expand the extent equally in all directions
... sort of retired...
