import arcpy, os arcpy.env.workspace = ws = r'G:\CamarilloGIS\Databases\GeoDatabases\HTE.gdb'  # put all the values in here      'old' : 'new' dictionary = {GIS_CE_' : 'HTE_CodeEnforcement', 'GIS_BP_' : 'HTE_BuildingPermits', ...etc...}  # this will loop thru the whole gdb and change any names that are in the dictionary variable for fc in arcpy.ListFeatureClasses():     if fc in dictionary:         old = os.path.join(ws,fc)         new = os.path.join(ws,dictionary[fc])         try:             arcpy.Rename_management(old, new, "FeatureClass")             print 'Renamed %s to %s' %(fc, dictionary[fc])         except:             print 'Could not rename %s' % oldtry: arcpy.Rename_management(GIS_BP_, HTE_BuildingPermits, "FeatureClass") except: print 'Could not find feature class' try: arcpy.Rename_management(GIS_CE_, HTE_CodeEnforcement, "FeatureClass") except: print 'Could not find feature class' # etc........
try:
    # rename fc here
except:
    arcpy.AddMessage('Could not find feature class')
if arcpy.Exists(feature_class):
    # rename fc here
else:
    # or pass
		# -*- coding: utf-8 -*-
# HTErename2.py
# Created on: 2013-03-04 13:45:45.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
try:
    # rename fc here
except:
# Local variables:
GIS_LX_Active_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_LX_Active_"
GIS_BP_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_BP_"
GIS_CE_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_CE_"
GIS_LX_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_LX_"
GIS_OL_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_OL_"
abc = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\abc"
GIS_PZ_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_PZ_"
GIS_TSI_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_TSI_"
GIS_UA_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UA_"
GIS_UF_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UF_"
GIS_UL_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UL_"
GIS_UR_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UR_"
GIS_URSVC_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_URSVC_"
GIS_US_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_US_"
GIS_USSVC_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_USSVC_"
GIS_UW_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UW_"
GIS_UWSVC_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_UWSVC_"
GIS_WF_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_WF_"
GIS_WF_SWID2_ = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\GIS_WF_SWID2_"
intersections = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\intersections"
HTE_BuildingPermits = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_BuildingPermits"
HTE_CodeEnforcement = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_CodeEnforcement"
HTE_LX_LocPoints_All = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_LX_LocPoints_All"
HDL_BusinessLicense_OL = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HDL_BusinessLicense_OL"
HTE_LX_Active_LocPoints = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_LX_Active_LocPoints"
HTE_ABCLicenses = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_ABCLicenses"
HTE_Planning_Zoning = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Planning_Zoning"
HTE_UtilitiesAll_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_UtilitiesAll_CX"
SQL_TrafficSignInv = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\SQL_TrafficSignInv"
HTE_Util_Fireline_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Fireline_CX"
HTE_Util_Landscape_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Landscape_CX"
HTE_Util_Refuse_Active_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Refuse_Active_CX"
HTE_Util_Sewer_Active_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Sewer_Active_CX"
HTE_Util_Sewer_Service_All_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Sewer_Service_All_CX"
HTE_Util_Water_Active_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Water_Active_CX"
HTE_Util_Water_All_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Water_All_CX"
HTE_WorkOrders = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_WorkOrders"
HTE_StormWater_WorkOrders_SWID2 = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_StormWater_WorkOrders_SWID2"
HTE_Intersections = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Intersections"
HTE_Util_Refuse_All_CX = "G:\\CamarilloGIS\\Databases\\GeoDatabases\\HTE.gdb\\HTE_Util_Refuse_All_CX"
try:
    # rename fc here
except:
# Process: Rename (2)
# Process: Rename (3)
# Process: Rename (4)
arcpy.Rename_management(GIS_LX_, HTE_LX_LocPoints_All, "FeatureClass")
# Process: Rename (5)
arcpy.Rename_management(GIS_OL_, HDL_BusinessLicense_OL, "FeatureClass")
# Process: Rename (7)
arcpy.Rename_management(GIS_LX_Active_, HTE_LX_Active_LocPoints, "FeatureClass")
# Process: Rename (6)
arcpy.Rename_management(abc, HTE_ABCLicenses, "FeatureClass")
# Process: Rename (8)
arcpy.Rename_management(GIS_PZ_, HTE_Planning_Zoning, "FeatureClass")
# Process: Rename (9)
arcpy.Rename_management(GIS_UA_, HTE_UtilitiesAll_CX, "FeatureClass")
# Process: Rename (10)
arcpy.Rename_management(GIS_TSI_, SQL_TrafficSignInv, "FeatureClass")
# Process: Rename (11)
arcpy.Rename_management(GIS_UF_, HTE_Util_Fireline_CX, "FeatureClass")
# Process: Rename (12)
arcpy.Rename_management(GIS_UL_, HTE_Util_Landscape_CX, "FeatureClass")
# Process: Rename (13)
arcpy.Rename_management(GIS_UR_, HTE_Util_Refuse_Active_CX, "FeatureClass")
# Process: Rename (14)
arcpy.Rename_management(GIS_US_, HTE_Util_Sewer_Active_CX, "FeatureClass")
# Process: Rename (15)
arcpy.Rename_management(GIS_USSVC_, HTE_Util_Sewer_Service_All_CX, "FeatureClass")
# Process: Rename (16)
arcpy.Rename_management(GIS_UW_, HTE_Util_Water_Active_CX, "FeatureClass")
# Process: Rename (17)
arcpy.Rename_management(GIS_UWSVC_, HTE_Util_Water_All_CX, "FeatureClass")
# Process: Rename (18)
arcpy.Rename_management(GIS_WF_, HTE_WorkOrders, "FeatureClass")
# Process: Rename (19)
arcpy.Rename_management(GIS_WF_SWID2_, HTE_StormWater_WorkOrders_SWID2, "FeatureClass")
# Process: Rename (20)
arcpy.Rename_management(intersections, HTE_Intersections, "FeatureClass")
# Process: Rename (22)
arcpy.Rename_management(GIS_URSVC_, HTE_Util_Refuse_All_CX, "FeatureClass")
Thanks for trying Caleb. I think I will just refine the model instead of trying to recode everything.
import arcpy, os
namedict = {'GIS_BP_': 'HTE_BuildingPermits','GIS_CE_': 'HTE_CodeEnforcement',
            'GIS_LX_': 'HTE_LX_LocPoints_All','GIS_OL_': 'HDL_BusinessLicense_OL',
            'GIS_LX_Active_': 'HTE_LX_Active_LocPoints','abc': 'HTE_ABCLicenses',
            'GIS_PZ_': 'HTE_Planning_Zoning','GIS_UA_': 'HTE_UtilitiesAll_CX',
            'GIS_TSI_': 'SQL_TrafficSignInv','GIS_UF_': 'HTE_Util_Fireline_CX',
            'GIS_UL_': 'HTE_Util_Landscape_CX','GIS_UR_': 'HTE_Util_Refuse_Active_CX',
            'GIS_US_': 'HTE_Util_Sewer_Active_CX','GIS_USSVC_': 'HTE_Util_Sewer_Service_All_CX',
            'GIS_UW_': 'HTE_Util_Water_Active_CX','GIS_UWSVC_': 'HTE_Util_Water_All_CX',
            'GIS_WF_': 'HTE_WorkOrders','GIS_WF_SWID_': 'HTE_StormWater_WorkOrders_SWID',
            'intersections': 'HTE_Intersections','GIS_URSVC_': 'HTE_Util_Refuse_All_CX',}
# Loop thru gdb
        try:
        except:
		Caleb,
I get this error. How do I define the dictionary?
File "C:/01Working_Directory/Python/HTErenamePythontest", line 17, in <module>
NameError: name 'dictionary' is not defined
import arcpy, os
            'intersections': 'HTE_Intersections','GIS_URSVC_': 'HTE_Util_Refuse_All_CX'}
# Loop thru gdb
    if fc in namedict:
        new = os.path.join(ws,namedict[fc])
        try:
            print 'Renamed %s to %s' %(fc, namedict[fc])
        except:
		Still no dice and I can't figure out why. This is why I use a batch file to open up ArcCatalog and run modelbuilder, its much easier.
