I want to find the first, second , third, etc. order neighbors of polylines preferably using arcgis.
2786
04-22-2016 02:17 AM
EhsanAbshirini1
I have a shape file containing street networks and I'd like to retrieve the IDs of all 1st,2nd, 3rd, etc. order neighbors for each line(street). Please note that this is different from finding the 1st, 2nd, 3rd closest line to one another line something that ARCGIS is currently able to do it by proximity analysis.
Any comments would be appreciated.
DanPatterson_Retired
like a heirachial network? About network analysis with hierarchy—Help | ArcGIS for Desktop
there is Stream in the spatial analyst for raster data
ot the utility networks approach A quick tour of geometric networks—Help | ArcGIS for Desktop
And if it is from a location and you need to group in generality, what you may be looking for is a Spanning Tree.  I have an implementation here Spanning Tree Tools
EhsanAbshirini1
Thanks Dan for your reply.
But what i am looking for is different. Clearly talking I want to have a table showing the IDs for all lines located in the immediate neighbor ( the streets that share an intersection with) of a desired line, these are the first order neighbors.Then for each of those streets that share an intersection with the desired line I would like to find their neighbors (these would be the second order neighbors), and so on...
Yes, I know what you mean. That is a variant of a spanning tree ... but from a start location location, I can't remember if my incarnation puts in the order number off hand, but it does produce a From and To id number so producing the heirachy is definitely possible.  The script uses Prim's algorithm if that makes any difference.  It should be possible to use the algorithm for polylines.
But I suspect that you are looking for what the Spatial Analyst's Stream tool does... except in vector world.
