I need to rename a list of feature classes (each one has only one feature) based on attribute data, i face an error says ExecuteError: ERROR 000840: The value is not a Data Element. for last line in this code... please advice
8026
21
03-12-2015 08:06 AM
Mohamed_AbdelhamidHassan
import arcpy
from arcpy import env
# Set the workspace for ListFeatureClasses
env.workspace = r"C:\Users\mohamed.abdelhamid\Desktop\Python\test\rename_test.gdb"
fcs = arcpy.ListFeatureClasses()
# Get the subdistric name from attribute
for itmes in fcs:
    field1  = "DIS_ARB_NA"
    field2 = "SDIS_ARB_N"
    cursor = arcpy.SearchCursor(itmes)
    for row in cursor:
        disname = row.getValue(field1)
        subname = row.getValue(field2)
        arcpy.Rename_management(in_data=itmes,out_data=disname + "_" + subname,data_type="FeatureClass")
i face the same error within the last line in the code!!!!!
  File "C:\Python27\ArcGIS10.2\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Users\mohamed.abdelhamid\Desktop\Python\test\renaming_3.py", line 21, in <module>
    arcpy.Rename_management(fc, str(dname + "_" + sname), "FeatureClass")
  File "C:\Program Files\ArcGIS\Desktop10.2\arcpy\arcpy\management.py", line 4048, in Rename
    raise e
ExecuteError: ERROR 999999: Error executing function.
The dataset name is invalid.
Failed to execute (Rename).
AhmedEl-Sisi
One optimization is to use arcpy.ValidateTableName to avoid any invalid feature class name as some characters like dash is not allowed.
import arcpy
env.workspace = r"C:\Users\mohamed.abdelhamid\Desktop\Python\test\Egy_SubDistricts_rename.gdb"
fields = ["DIS_ARB_NA","SDIS_ARB_N"]
for fc in fcs:
    with arcpy.da.SearchCursor(fc,fields) as cursor:
        for row in cursor:
            fullname= row[0] + row[1]
        del row, cursor
    print fullname
    outfc = arcpy.ValidateTableName(fullname,env.workspace)
    arcpy.Rename_management(fc, outfc, "FeatureClass")
