How to get GML from WPS
475
09-08-2016 03:30 AM
DušanCibulka
Hello,
I have problem with WPS published with AGS 10.4.1.
I would like to return GML from WPS as output parameter.
Simple example, it works well:
featureClassFromGML = arcpy.GetParameter(0)
arcpy.SetParameter(1, featureClassFromGML)
Return GML:
<wps:ProcessOutputs>
<wps:Output>
<ows:Identifier>TransformedData</ows:Identifier>
<ows:Title>TransformedData</ows:Title>
<wps:Reference mimeType="text/xml" href="http://<servername>/arcgis/rest/directories/arcgisjobs/test_wps_gpserver/j63c4ddcb8a44445ba563cef2d1511ef3/scratch/_ags_j63c4ddcb8a44445ba563cef2d1511ef3TransformedData.xml"/>
</wps:Output>
</wps:ProcessOutputs>
</wps:ExecuteResponse>
This is OK.
But if I would like to do some processing of input features:
arcpy.CopyFeatures_management(featureClassFromGML, 'in_memory\\fc_in')
arcpy.SetParameter(1, 'in_memory\\fc_in')
WPS return exception:
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows" version="1.1.0" language="en"/>
REST service status is esriJobSucceeded without TransformedData.
Or:
featureSet = arcpy.FeatureSet(featureClassFromGML)
arcpy.SetParameter(1, featureSet)
REST service status is esriJobSucceeded with TransformedData in JSON format.
Type of input and output parameters are Feature Set (GPFeatureRecordSetLayer).
Execute request is in attachment.
Do you know how to setup an output parameter to returned GML document?
