How to fill in gaps in a USGS DEM
790
06-05-2014 11:44 AM
JerryHolton
Does anybody no how to fill in gaps in a USGS DEM? I imagine the best way is to interpolate the missing values from the neighboring
pixels. I believe there is probably a Raster Calculator formula. I have found a few in other forums but they never seem to work. This could be because they are done in older versions of ArcGIS, but I am not sure. I am working with 10.2.  Any ideas?  Thank you so much.
Tom
IanMurray
Honored Contributor
Depending on how large the gaps are, you might want to try the Resample Tool (Data Management).  Check the help to see which method to use
