Hello there;
I have above 2000 points where each point has a field which indicates a number of incidents from 0 to 300.
I want to draw a polygons around of these points where total number of incidents = 1000.
what would be the best way performing such analysis?
thanks in advance.
BR;
Just a clarification.
So, each polygon should contain multiple points, sum of whose "Num_of_Incidents" field will be 1000?
Tough one ![]()
hi Jayant, thanks for your concern.
Yes, one polygon should cover more than 4 points in order to achieve minimum sum of 1000.
I haven't mentioned but the distance of each points should be minimal therefore we will have multiple neighboring polygons which has same/similar number of incidents covering multiple points.
Its logically simple and can be done manually but couldn't find out how to do it automatically.
