How to automatically calculate the angle between two intersecting polylines
22166
33
05-01-2016 02:43 PM
FatmaŞenol
I have 52338 polygons which needs to be edited using the following rules;
The distance between the intersection point and the closest vertices on two  intersecting
polylines should be at least 1.2 meter as shown below. On the  other hand the distance
between two closest vertices should not be less than 2 meters. What I'm trying to do is
automatically calculate  the optimum angle angle between two polylines to meet the given
two rules as I explained above.
ArcGIS Desktop doesn't have such built-in tool to calculate the angle as far as I know.
Is there any tool or script that you could suggest ?  If there is no such solution it would
also be great, to select vertices which are  2 meters apart from the intersection point.
I will be grateful for any help you could provide.
Regards
WesMiller
I have it downloaded. Once i get caught up i'll look at it.
WesMiller
Attached is an updated model and the results. Below are the steps I used.
  1. open new empty map
  2. add your polygons
  3. convert your polygons to lines Feature To Line—Help | ArcGIS for Desktop
  4. delete identical Delete Identical—Help | ArcGIS for Desktop
  5. open model in edit mode and set the input feature class to the above created and set other parameters as desired
Hope this helps.
The overlaps still give unwanted results
FatmaŞenol
Hi Wes,
Please accept my apology for not writing earlier. I tested the updated model for several times and the result
seems to be correct. I have only one more question if you don't mind my asking. The make feature layer
tool in model does not create a point layer when I change name of the output layer and the workspace.
Did I miss something ? I attached the screenshot of  this tool to clarify my question. Could it be possible
to change the workspace or feature dataset ?
WesMiller
