How to analyze signal intersection with crashes.
6113
13
02-03-2015 07:15 AM
ElizabethPutnam
I been given an assignment to group accidents that are near a intersection. I was given three shape files one for signal intersections, all intersections and accidents along the road for one county.
The problem that I am running into is overlapping buffers at the intersections. I am doing 250 feet buffers at the intersection. The reason for this is some intersections are too close to each other.
The data that was given to me for intersections are broken into two or more dots one for traffic going left and the other for traffic going right at the same intersection. How can I get these two dots to join through out the whole county instead of doing it one by one.
If any one has done something similar to this and would be able to guide me it would be very helpful.
Thanks.
ElizabethPutnam
I tried it and it only created a distance field in the attribute table. I would like to include the nearest point into the nearest buffer. Its probably not even possible but I still thought I throw it out there.
JoeBorgione
I thought the NEAR also creates a FID field that identifies the nearest Feature by Object ID.  That provides a mechanism by which to join the orphaned points to the nearest polygon.  Depending on the number of orphaned points, it may or may not be practical to analyze the data manually.  At best I'm a hack at Python; perhaps someone else could chime it for an automated solution.
JoeBorgione
I wonder if buffering your intersections isn't the way to go.  I just created two point feature classes: wrecks and intersections.  Then I performed a near between them.  Here is a snapshot of the augmented wrecks attribute table:
Look at wreck-points (OID) 1 & 2.  They are closest to the intersection with OID 2.  Clearly this is an extremely simplified analysis, but if I wanted to know which intersections have the most wrecks, I'd summarize this table on the NEAR_FID to get a count.  In this case intersection OID 10 only has one wreck associated with it and all the rest have two.  With a summary table you'll get a count of whatever you summarize on.  Then you could join/relate this information back to the intersections.  Make sense?
ElizabethPutnam
Thanks a lot for your help.
