How can I determine if a featureclass in a FGDB is compressed within the geoprocessor
851
07-28-2010 02:30 AM
AlPiszcz
CompressFileGeodatabaseData and UncompressFileGeodatabaseData operate on a FC. How do I determine if a featureclass is compressed? I would like to list a catalog of FC's using the geoprocessor showing the status of the FC (compress/uncompressed). I understand ArcCatalog displays this information however I am interested in accessing through the Python API. IMO the attribute should be support by the Describe command, however I do not see anything related to compressed status in describe.
RhettZufelt
MVP Notable Contributor
I see nobody has responded, but was wondering if you ever found a solution for this?
R_
Professional ESRI beta tester
