Geostatistical layer to raster empty
6814
11
03-22-2016 08:07 AM
RajPatnaik
I'm running ArcGIS 10.2 and have been using the Geostatistical Wizard to create an interpolation layer using ordinary kriging. The Wizard has successfully run the kriging operation and produced a geostatistical layer output, which looks quite reasonable. However, when I try to export the GA layer to a raster (I've tried both GA Layer to Grid and Data->Export to Raster from the TOC) the resulting raster is empty. The range of the raster layer as shown in the TOC is -3.4...e+038 to 3.4...e+038, and when I open the properties for the layer, no summary stats are shown. Calculating Statistics is not doing anything, it runs, but doesn't change the summary stats and the raster still appears empty. The projection information of the original point data and the output raster match. Herewith attached the Jpeg which shows the geostatistical result and exported result with -3.4...e+038 to 3.4...e+038
Let me know if I'm missing something...Please advise!
RajPatnaik
Thank you Steve, In the environment, "Mask" was set to different layer.
It worked!
SteveLynch
I thought that the GALayerToGrid tool gave you that result.
Please can you create a MapPackage​ and email it to me (slynch@esri.com)
-Steve
