Geoprocessing tools not working in Arcgis pro
3202
09-30-2022 12:26 AM
RomuldKiobya
Hii
I got this challenge when I work with ArcGIS pro. When I  opened any tool in geoprocessing tool Igotbyhis error
tool has failed to open
When ilooked inside
'analysis.Clip'
The external component has thrown an exception.
Can I get an assistance to resolve this issue?
Corey_M
Hi @RomuldKiobya
Could you please confirm the version of ArcGIS Pro you are using? Can you confirm the licensing level inside ArcGIS Pro and appropriate permissions inside ArcGIS Online?
What type of data is it that you are trying to run the tool with? Is this data produced by yourself or did you get it from another source?
Have you attempted to repair the installation? please check the following link for troubleshooting issues with the software installation, step 2 outlines how to run a repair How To: Troubleshoot installation and uninstallation issues (esri.com)
Corey
RomuldKiobya
I'm using Arcs pro 2.9.2,  license personal use, and I'm an administrator
EmilioTomeBlasco
The same problem with ArcGIS Pro 3.0.2
SU license Advance with some extensions (Production, spatial, ...)
I did a clean uninstall.
'analysis.Clip'
External component has thrown an exception.
I Can´t run any tool.
alexislitvine2
I have the same issue using 3.1.2. Did either of you find a solution?
alexislitvine2
@Corey_M - did you follow up on this issue?
