Geoprocessing tool
2266
07-25-2021 03:49 PM
OgunfolajiDare
I was to perform xy to point using the tool but it displays, script associated with this tool does not exist. It displays the same information for feature to geodatabase. Other tools are working except those in script format. A copy of the displayed information is attached. Please help to resolve this issue thank you.
DanPatterson
MVP Esteemed Contributor
where is the script?  have you looked for in in the data that you downloaded for the lessons?
... sort of retired...
OgunfolajiDare
The script is not about the data, it is the tool itself that I was trying to use that displayed that that script associated with the tool does not exist. I also made effort to check the tool by right clicking it to edit it but attached was the message displayed.
DanPatterson
probably it is looking for a *.py file and not *.txt
DavinWalker2
Try running the ArcPro software installer again and select repair.
Ogunfolaji_Dare
I have tried restalling it but is still the same thing
