Geoprocessing Service in 10 - Quanity of input records?
547
06-03-2011 05:51 AM
HeatherLizama
Has anyone run a GP service that had a FC of approx 300,000 records as an input parameter?
My service is not running with the total number of input records. I have to decrease the FC to 2200 records for it to run.
The whole point of the service is to select a portion of the 300,000 records based on a bounding location into smaller FCs.
MostafaFouly1
Hi nuisanceheather,
I don't think that the best solution is to run the 300,000 records on the same shot...So you might
"select the portion of the 300,000 records based on a bounding location into smaller FCs" and after that you can run 2 submit jobs...on the complete event of the first you can run the other one or you can use recursion.
Fouly.
