Hi Dana,
Are you referring to NIM071576: The Feature to Point tool creates a different center point when the option to constrain the point to the inside of the polygon is enabled, but the center point is actually inside the polygon. ?
If so, it shows as having been fixed in the next release.
Best,
Melanie S.
Dana, if possible, please share a sample data so I can double check for you. Thanks.
