Feature optional in modelbuilder
2364
08-21-2012 12:43 PM
mariangalie
Hello!!
         How can I declare a feature class like a optional variable? Because I build a model and I want to use it in others projects without some feature class, fara a edita modelul
          Thanks you!
mariangalie
Hello!!
How can I declare a feature class like a optional variable? Because I build a model and I want to use it in others projects without some feature class, without edit model
   Thanks you!
JonathanQuinn
Esri Notable Contributor
You can make the feature class a parameter and then make it optional.  Take a look at this resource for guidance.
mariangalie
[ATTACH=CONFIG]17155[/ATTACH]
I've tried what you said......but I want someting like in image
Thanks  for your help
VeronicaMartin_Martin
Hi!!
Check this post (http://forums.arcgis.com/threads/2368-trying-to-set-some-parameters-as-optional-in-modelbuilder)
Apparently, in ArcGis 9.3, if the input is connected to a tool it cannot be declared as optional. Just disconnect it, set it as optional and then connect it again
