Fastest tile creation - CPU usage near 100% during the tile creation
3248
06-19-2017 11:10 PM
MarkMindlin
We use the tool "Manage Tile Cache" in ArcMap 10.5, for ArcGIS Server 10.3.
Parameter "area_of_interest" is the feature class created by CacheWorx "Coverage To Feature" Level 19
The help says: "For the fastest tile creation, your CPU should be working near 100% during the tile creation"
Having 16 cores CPU, and using ParallelProcessingFactor 100% or 16
the CPU usage is very low - between 3 to 8 percents
Any help will be greatly appreciated.
MarkMindlin
We figured out the one reason: area of interest was the feature class with number of polygons more than 1.
After we have dissolved the feature class it seems better: now, 20-30% of CPU usage (still not 90-100 )
Anthony, thank you for your response. We use 10.5, and 16 ArcSOCP processes for 16 core CPU are present.
Another indication of the "proper" use of the tool is number of temporary  *.lock" files in the cache folder.
AnthonyMikelson
I just upgraded from 10.4.1 to 10.5 and it appears the Manage Tile Cache geoprocessing tool is not respecting the multithreading like it is supposed to.  In 10.4.1 if you had parallel processing set to 100% then the amount of ArcSOCP should match the number of cores.
Since upgrading to 10.5 I do not see any ArcSOCP processes at all and the caching appears to be much slower.
MarkMindlin
AnthonyMikelson
After further research I had to eventually uninstall the Desktop Background Geoprocessing.  Not sure why yet, but it is working now.
MarkMindlin
We also uninstalled Desktop Background Geoprocessing.
MarkMindlin
In order to find a workaround I tried to use a script with multiprocessing.
Unfortunately, it has an error at the run time. Please help to make it working.
The script
#run “Manage Tile Cache” tool in parallel processing
import arcpy
import multiprocessing
import os
import glob
import sys
import traceback
from multiprocessing import Process, Queue, Pool, \
    cpu_count, current_process, Manager
arcpy.env.overwriteOutput = True
arcpy.env.scratchWorkspace = "in_memory"
AAA_Imagery = "D:/gisdata/imagery/public_AAA_Imagery/AAA_Imagery"
Manage_Mode = "RECREATE_ALL_TILES"
Scales__Pixel_Size___Estimated_Disk_Space_ = "564.248588"
Best_WebM = "D:/gisdata/imagery/BestMosaic_2017test.gdb/Best_WebM"
Level_20_coverage = "D:/gisdata/imagery/Levels_coverage.gdb/Level_20_coverage"
def execute_task(bundleAOI):
    try:
        result = arcpy.ManageTileCache_management(AAA_Imagery, Manage_Mode, "", Best_WebM, "ARCGISONLINE_SCHEME", "", Scales__Pixel_Size___Estimated_Disk_Space_, bundleAOI, "", "591657527.591555", "282.124294")
        print(arcpy.GetMessages())
        print "result: " + result
    except Exception, e:
        e.traceback = traceback.format_exc()
        raise
if __name__ == '__main__':
    #get individual bundles, add it to a dictonary
    bundles = {}
    count = 1
    for bundle in arcpy.da.SearchCursor(Level_20_coverage,["*"]):
        bundles[count] = bundle
        count += 1
    # create a process pool and pass dictonary of extent to execute task
    pool = Pool(processes=cpu_count())
    pool.map(execute_task, bundles.items())
    pool.close()
    pool.join()
The error (see the image)
