Extract mean raster values to line
8139
12-06-2020 05:11 AM
PatrickGreber
Hello all!
I'm currently working on a samll GIS-Project but I got stuck on a problem. Is there a possibility to extract the mean value of raster cells, that were crossed by a line and then ad this mean value to the line? I have one dataset with lines (vector) and another raster dataset with different values. I would like to add a column to the line dataset with the mean values of the crossed rasters by that specific line.
Thank you for your help and support!
2 Solutions
DavidPike
MVP Notable Contributor
I think Add Surface Information will do this (with the right parameters set) Add Surface Information—Help | ArcGIS for Desktop , Add Surface Information (3D Analyst)—ArcGIS Pro | Documentation
If you don't have 3d analyst, I'd first try and find someone who does! but there'd be some kind-of process of 'Extract by Mask' to get only the raster cells coincident with the polylines, then theres many options i guess, I would:
convert the cells to polygons, then do a spatial join with a merge rule of 'SUM' for the grid_code field (or whatever it's called - I cant remember)
Edit - 'Mean' option, not 'SUM'
DavidPike
Ah, I'm not sure on that one.  You could do the raster to polygon method then a spatial join, use the join_count to count the number of raster cells the line passes through, then the sum would be the mean * that count (I think).  There may be other options but I'm not sure.  I think that workflow is valid, but a raster to polygon can be very intensive depending on the extent and cell-size of your area (definitely extract by mask before you do the raster to polygon).
DavidPike
PatrickGreber
Hi David,
Thank again for your help, it worked perfectly with "add surface information"! I was looking at a lot of workarounds and glad that your solution did not require this=)!
Would there be a way to calculate the SUM too, or would this require other solutions?
Thank you soo much!
DavidPike
