Extend polygon to line in batch?
6864
11
02-05-2015 08:18 AM
NathanialStory1
I am looking for a good way to 'fill the gaps' between my county's polygon layer and a land use layer I inherited.Temp.JPG
I need the green symbolized land use polygons to, at the very least, overlap the red lined parcel polygons. There are several thousands of this example throughout my county and I would like to avoid correcting them by hand if I can. Does anyone have a solution or tool for my situation? Thank you!
ChrisDonohue__GISP
That sounds like an interesting possibility.  Could work.
Chris Donohue, GISP
NathanialStory1
Micah,
After running the loop over 6 parcel shapefiles I couldn't tell any difference in the movement of the lines (I left the cluster tolerance at the default value) Perhaps with many more iterations and a bit of wizardry with the cluster tolerance it might have worked. I ended up doing it the old fashioned way.
Thanks again for all your help!
