ERROR IN CUMULATIVE AREA FIELD IN THE TABLE IN ARCMAP
833
09-12-2023 12:16 AM
InshaBatool
I performed zonal stats table first then I want to add hypsometric curve in my study. For that I required a cumulative area field in table but everytime I tried , there is an error I face. I didn't detect what is the problem with the expressions I give. Can someone help me out in it. I also attached the SS files of the steps for further assistance.
DanPatterson
MVP Esteemed Contributor
Your Type is set to String, shouldn't it be number? do you have to use a VB parser?
... sort of retired...
InshaBatool
Actuallly in type I use number first but that time I got same error, as an instance I change it into string.
