Tip 1: Don't use shapefiles. File GDB featureclasses are much more reliable and consistent when it comes to editing.
Tip 2: When getting an additional warning that the number of records don't match the number of rows, make a backup copy of the shapefile. Then delete all of the file extensions for the shapfile except the shp, dbf, shx. Copy the dbf to another directory and then add it to a blank ArcMap where you can edit it. Hopefully it will be obvious which records should be deleted. Typically these will be exact duplicates. Delete them both. Then go back to the copy where the shp is and rename the dbf to "<name>_old" then replace with the edited dbf file.
Worked great for me!
Same frustrating problem here. Anything tryied. No fix founded
Please see this as a possible solution
Error: 000229: Cannot open
I was having this issue running the Append tool in ArcMap on a feature located in a feature dataset. I ran the tool in ArcCatalog and it worked.
