Equivalent GP tool for �??create network location�?� tool,
1994
10-18-2013 11:49 PM
JamalNUMAN
Legendary Contributor
I couldn�??t find the GP tool for the �??create network location�?� such that one can choose the stops manually by clicking the maps.
[ATTACH=CONFIG]28455[/ATTACH]
Then how this tool (create network location) can be integrated into a model?
[ATTACH=CONFIG]28456[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
StefanHaglund1
Hi Jamal,
Set your input locations on the Add Locations tool as a parameter in your model and its data type is feature set:
http://resources.arcgis.com/en/help/main/10.1/index.html#/A_quick_tour_of_using_Feature_Set_and_Reco...
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Hi Jamal,
Many thanks Stefan for the help,
Choosing the input location type to be �??feature set�?� solves my issue.
The problem now is that the output �??best route�?� is not displayed. Is there a way to show it in the map as the model tool is run?
[ATTACH=CONFIG]28732[/ATTACH], [ATTACH=CONFIG]28733[/ATTACH]
