Enabling Personal Geodatabase (mdb) download from Extract Data Task
822
10-07-2011 06:57 AM
JonFisher
I've been using the extract data task along with the download widget in ArcGIS Viewer for Flex, and I've had a request to add personal geodatabase as one of the available formats for download. I looked at the model, and the properties for the feature class type don't seem to include a list of valid formats, nor did I see it in the Python for the Extract Data piece. Any idea where to enable this? I did see that the Python had some code for handling mdbs, so I'm guessing there's something simple I'm missing. Thanks for any tips!
Jon
KevinHibma
Jon,
For sure. You want to add the following type "Personal Geodatabase - MDB - .mdb".
The last part of the help topic here gives some context.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/GP_Service_example_Clip_and_ship/002v0...
Basically copy the task into a model of your own. From Model > properties of your model, make sure the feature format is a value list, and add the entry  "Personal Geodatabase - MDB - .mdb".
Hope this helps.
JonFisher
Thanks Kevin! I was confused because when I edit either the default ESRI "Extract Data Task" model or the local version of it I have, when I right-click on Feature Format and select properties, it says that the variable contains a single value. However, when I follow your instructions exactly and go to the properties of the entire model, I see the list. It's working for me now, thanks again!
