dwg to shp
990
10-07-2010 10:57 AM
OlivierOlivier
Would someone be so kind to give me the tools name to convert dwg files to shp inside modelbuilder ? I tried copy, make feature layer, feature class to shp, none works.
Thanks a lot
Olivier
JakubSisak
Honored Contributor
"Cad to Geodatabase" tool. Then you can use "Feature Class To Shapefile" to convert to shp.
OlivierOlivier
Thanks for your answer. I have no "Cad to Geodatabase" tool but I suppose it became "to Geodatabase/import from CAD", because of the translation.
The problem is that this tool creates a "folder.GDB" which is not allowed as input for "to shapefile/feature class to shapefile" even if the description seams to fit perfectly.
