Displaying Geoprocessing Results
2862
04-01-2013 09:25 AM
joshwheeler1
I can't get the results to display to ArcMap when running my model from the tool dialog box. I can only get the results to display when running the model from the model builder window.
I do have the box checked to 'Add the results of geoprocessing operations to the display' under Geoprocessing Options. I also made sure the box was checked to 'Make newly added layers visible by default' under ArcMap Options.
My model is selecting features based on a query then creating a feature layer based on the selection.
Thanks for any help.
DaleHoneycutt
Short answer:
You need to make the output variable of your model (the new layer) a Model Parameter.  Right-click the variable and choose "Model Parameter".
See Creating Model Parameters in the help.
DaleHoneycutt
Short answer:
joshwheeler1
That worked, thanks a lot!
