Count number of features in FeatureClasses
10803
12
06-09-2010 11:16 PM
Andreas_ForøTollefsen
Hi all.
What i want to do is to create a list of the number of features in each of my featureclasses.
I have already created a list of all the featureclasses in the workspace.
Now i need to iterate through all of these and count the number of features in each featureclass.
import arcgisscripting
import os
gp = arcgisscripting.create(9.3)
gp.Workspace = "H:\\geodata\\"
print "Generating list of featureclasses in" " " + gp.Workspace
fcList = gp.ListFeatureClasses()
for fc in fcList:
    print fc
Anyone have a suggestion? I assume i need to use the cursor object?
JustinGinn1
You have no idea how much time I wasted because of this problem... wow. THANK YOU SO MUCH! I thought I was going insane... I had imported the 9.3 geoprocessor on a new version of the script, and I could not figure out why it wasn't working.
dgesridgesri
Greetings,
Is there a way to get all the featureclasses in a worksapce through vb.net code?
please advise.....
JohnRoberts1
Sub main()
Dim strServer As String
Dim strInstance As String
Dim strDB As String
Dim strUser As String
Dim strPass As String
Dim strVersion As String
strServer = "GISSDE"
strInstance = "sde:sqlserver:gissde\production"
strDB = "Utilities"
strUser = "gisreader"
strPass = "gisreader"
strVersion = "sde.DEFAULT"
        Dim pPropset As IPropertySet
        Set pPropset = New PropertySet
            With pPropset
            .SetProperty "Server", strServer
            .SetProperty "Instance", strInstance
            .SetProperty "Database", strDB
            .SetProperty "User", strUser
            .SetProperty "Password", strPass
            .SetProperty "Version", strVersion
            End With
            Dim pWorkspace As IWorkspace
            Dim pFact As IWorkspaceFactory
            Set pFact = New SdeWorkspaceFactory
            'pWOrkspace = pFact.Open pPropset, 0
            Set pWorkspace = pFact.Open(pPropset, 0)
            Dim pFeatws As IFeatureWorkspace
            Set pFeatws = pWorkspace
            Dim pVerWorkspace As IVersionedWorkspace
            Set m_pVersionWork = pWorkspace
            Dim sDatasetName As String
            sDatasetName = "<All>"
            If sDatasetName = "<All>" Then  'Checking all layers in all datasets
                Dim pWork As IWorkspace, pEnumData As IEnumDatasetName
                Dim pFeatDatasetName As IFeatureDatasetName, pDataset As IDatasetName
                Dim pEnumFeatClassName As IEnumDatasetName, pFeatClassName As IDatasetName
                Dim pVersionedObject As IVersionedObject
                Dim pFC As IFeatureClass
                Dim pName As IName
                Dim lFCount As Long
                Set pWork = m_pVersionWork
                'process data outside of feature datasets...
                Set pEnumData = pWork.DatasetNames(esriDTFeatureClass)
                Set pFeatClassName = pEnumData.Next
                Do While Not pFeatClassName Is Nothing  'Loop through the feature classes
                    ' "Checking " & pFeatClassName.Name & " layer for updates . . . "
                    Set pName = pFeatClassName
                    Set pFC = pName.Open
                    lFCount = pFC.FeatureCount(Nothing)
                            Debug.Print (pFeatClassName.Name) & " Has " & lFCount & " Features"
                Loop
                'now process all feature datasets
                Set pEnumData = pWorkspace.DatasetNames(esriDTFeatureDataset)
                Set pDataset = pEnumData.Next
                Do While Not pDataset Is Nothing  'Loop through the dataset names
                    Set pFeatDatasetName = pDataset
                    Set pEnumFeatClassName = pFeatDatasetName.FeatureClassNames
                    Set pFeatClassName = pEnumFeatClassName.Next
                    Loop
                Loop
            End If
End Sub
