Count number of features in FeatureClasses
11032
12
06-09-2010 11:16 PM
Andreas_ForøTollefsen
Hi all.
What i want to do is to create a list of the number of features in each of my featureclasses.
I have already created a list of all the featureclasses in the workspace.
Now i need to iterate through all of these and count the number of features in each featureclass.
import arcgisscripting
import os
gp = arcgisscripting.create(9.3)
gp.Workspace = "H:\\geodata\\"
print "Generating list of featureclasses in" " " + gp.Workspace
fcList = gp.ListFeatureClasses()
for fc in fcList:
    print fc
Anyone have a suggestion? I assume i need to use the cursor object?
Thanks Dan.
That should be an easier way of doing it.
I wrote the script below, and it did work. However, I think getCount would be better.
Thanks.
import os
print "Generating list of featureclasses in " + gp.Workspace
print "Listing all featureclasses in " + gp.Workspace
for fc in fcList:
    print fc
print "listing fields in featureclasses"
for fc2 in fcList:
    fn = gp.ListFields(fc2)
    print str(fc2) + " " + str(len(fn))
print "Counting number of records in each featureclass"
for fc3 in fcList:
    cur = gp.SearchCursor(fc3)
    row = cur.Next()
    alist = []
    while row:
        row = cur.Next()
        alist.append(row)
    alist.sort()
    print "number of features in " + fc3 + " are: " + str(len(alist))
del fcList, fc, fc2, fn, cur, row, alist
ChrisMathers
I asked the same recently and was told I would need to do count=gp.getcount(file) then count=int(Count.getOutput(0)) because what you are given as a result of the getcount tool is a geoprocessing result object not a number. I didnt actually need to though. For some reason doing count=gp.getcount(file) then featurecount=count worked fine. I really dont know why as that should make featurecount just another link to the result object.
JoelCalhoun
Per the help example, the getCount method changed from 9.2 to 9.3.
So if you are using the old 9.2 geoprocessor you can pass the resulting count directly to a variable.
If you are using the 9.3 geoprocessor you have to extract the value from a result object as the previous poster mentioned.
ArcGIS Script example:
# Using a 9.2-version geoprocessor
gp = arcgisscripting.create()
gp.workspace = "D:/Workspace"
count = gp.GetCount_management("roads")
# Using a 9.3-version geoprocessor
result = gp.GetCount_management("roads")
count = int(result.GetOutput(0))
I found this out when my code failed when we switched to 9.3.  I don't remember ESRI announcing this change like they did the change to python lists so it was a little bit of a suprise.
Joel
KimOllivier
Honored Contributor
You can see the counts of each featureclass in ArcCatalog without any Python scripting.
Add features count as a column in the options for display and then touch each featureclass to update the metadata.
then when you select the geodatabase or folder the counts will display in the listing.
RandyKreuziger
Joel
Thanks Joel for pointing that out.  My python scripts seem to break with each new ArcGIS release!  It is very time consuming updating even a small number of mission critical python scripts with testing, etc.  But with each year I have more and more scripts to maintain.
BrianWilson
ESRI doesn't think code we wrote last year is important apparently. It also makes exchanging scripts with our clients impossible. Oh well.
Does anyone know where the "gcResult" object returned by GetCount is documented? The page for "Get Count" has no indication of what is being returned.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0017000000n7000000.htm
Thanks Brian
KevinHibma
The help topic is here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Result/000v000000n7000000/
Sample code:
import arcpy
inTable = arcpy.GetParameterAsText(0)
result = arcpy.GetCount_management(inTable)
print result.getOutput(0)
BryceStath
thanks
to elaborate a bit..
In ArcCatalog (9.3.1), Tools -> Options -> Contents(tab) -> Which Metadata... (2nd pane) -> # of Features
