Copy the shape features a number of times based on the numeric field
1112
5
02-20-2021 09:31 PM
RIKAHARUYAMA
Hello. I posted this question yesterday(<https://community.esri.com/t5/geoprocessing-questions/phython-script-typeerror-range-integer-end-arg...>) and thought it was solved, but there's another problem found...
I've run the module below. The empty feature class was created but there's no geometrical shapes created.
def main():
    import arcpy
    import os
    fc_in = r"D:\forest\CHISAN\shp\test.gdb\PT_merge" # this one exists
    fld_count = "Count"
    fc_out = r"D:\forest\CHISAN\shp\test.gdb\PT_merge_duplicate" # this one will be created
    sr = arcpy.Describe(fc_in).spatialReference
    # create the empty output featureclass
    path, name = os.path.split(fc_out)
    arcpy.CreateFeatureclass_management(path, name, "POLYGON", fc_in, "SAME_AS_TEMPLATE", "SAME_AS_TEMPLATE", sr)
    # insert the features into the output fc
    with arcpy.da.SearchCursor(fc_in, '*') as curs_in:
        flds_in = curs_in.fields
        idx_cnt = flds_in.index(fld_count)
        with arcpy.da.InsertCursor(fc_out, '*') as curs_out:
            for row in curs_in:
                cnt = row[idx_cnt]
                for i in range(0,int(cnt)):
                    curs_out.insertRow(row)
if __name__ == '__main__':
    main()
I think something is wrong with  "# insert the features into the output fc" part.
Would be very appreciated if someone could lectuer me how to solve this problem.
Thank you.
DanPatterson
MVP Esteemed Contributor
If you got an error, provide it.  That will be the key.  Perhaps the fld_count field type is wrong?
... sort of retired...
RIKAHARUYAMA
Thanks for the reply. The module run with no error code, but just the empty feature class was output,  which have the database multiplied a number of times based on the numeric field "Count". The database file has been created collectly without the geometrical shape feature 😞
DanPatterson
The original question in your previous post indicates the purpose of the script.
I have a point feature class with a Count field.  I want to copy each feature in the feature class a number of times based on the number in the Count field.  For example, if a feature has a Count value of 6, I want six new features created with all the same attributes as the original feature.
So... to confirm you have a point featureclass and you want to replicate each feature a certain number of times based on a Count field?
@XanderBakker produced a toolbox as well, perhaps you should look at that as well
RIKAHARUYAMA
Thanks for your reply. I have a polygon feature instead of point feature, so  I changed the line below from "POINT" to "POLYGON".
Probably that's why the shape feature was not made..?
DanPatterson
That would be the case, since it was designed for points
