Collector / Field Maps requiring global ID-based relationships
799
12-10-2021 05:56 AM
PaulLohr
Is it true that both Collector (v. 21.0.4) and Field Maps (v. 21.3.0) require global ID-based relationships for those relationships to function properly? We are using ArcGIS Server 10.7.1.
If so, are there out-of-the-box tools which would facilitate migration to this system? Tools from either Desktop or "Pro" would be fine.
Reference:
https://community.esri.com/t5/data-management-questions/migrating-to-globalid-relationship/m-p/42600...
Thanks for any help.
ABishop
Hello Paul,
What format is your data currently in?
Amanda Bishop, GISP
PaulLohr
The data is stored in SQL Server.
ABishop
Are you wanting to migrate and manage the data in the newly migrated database or are you wanting to maintain the data in the SQL server database and continual convert it with GUID to complete the geoprocessing?
Amanda Bishop, GISP
PaulLohr
There is no need to migrate. Relationships were established using text data type primary and foreign keys. Hoping to find out-of-the-box tools to migrate to global ID-based relationships.
